quote, "I'm assuming the return from the various functions is the large line that runs parallel with the 2 power steering lines and 1 main hyd. line (from the dash to the front of the tractor) that connects to the oil cooler?" No, this is not the function return circuit. This line flows transmission pump oil, after it is cooled, that is not used by a function, back to sump. quote "I also wonder what the difference(internal in the pump) is between the port on the top of the main hyd. pump that connects to the cooler and port on the L.S. of the pump that connects to the steel line(supply from trans. pump?)??" The inlet port on the pump, and the port to the cooler is a common passage. If a function is being used, the pump takes what oil is needed for the function, and the rest is cooled and sent back to sump. On the pre 1969 tractors, the function return, steering and SCV, is a steel line to the filter relieve housing, combines with transmission pump oil, to filter, and back to the main pump. (need for sure what year the 3020 is) The function return oil sees the original check valve, before it gets to the add on check valve, and will not prevent function return oil from migrating back through the old valve and trans pump, when the clutch pedal is down. With a good hydraulic system, and properly plumed loader, you should have ten minutes of all functions, with the clutch pedal down.
