1941 H Governer
Russell6HP
05-07-2008 09:26:44
I have re-installed my governor after a rebuild. Is there any special timing I must do with the governor gearing itself (not the mag)?
Mike M
05-07-2008 09:30:45
 Re: 1941 H Governer in reply to Russell6HP, 05-07-2008 09:26:44
As long as the slot in the coupling is horizontal - - when #1 is at TDC you will be fine.
PBrowning
05-07-2008 11:37:40
 Re: 1941 H Governer in reply to Mike M, 05-07-2008 09:30:45
And if it isn't, you will need to lift the governor and remesh those gears until the magneto drive flange slot IS horizontal with # 1 piston at TDC.
You mentioned a rebuild. Sometimes (not often) the slotted magneto drive flange, though keyed, will end up on the governor shaft at a spot unlike where it was to begin with (either on the shaft further or less). And this can cause great grief when installing the magneto.
At this writing, I simply encourage you to see that the magneto fits into the drive slots sufficiently to drive the magneto, however there should be a bit of slack. If the magneto seems to be butting up against the drive flange before magneto's body flange is up against the governor housing, that could spell trouble. This is a simple word of caution -- something to check out during magneto reinstallation.
For more on issues involving the Model "H" tractor, check in at the JD-H Restoration Site (below).(PatB)
Russell6HP
05-07-2008 16:00:11
 Re: 1941 H Governer in reply to PBrowning, 05-07-2008 11:37:40
Thank you very much for the help, I'll give it a try!
