850 SCV
leon
05-07-2008 08:37:20
Anybody know of a source for an SCV for an 850 compact tractor?
Mike M
05-08-2008 12:05:28
 Re: 850 SCV in reply to leon, 05-07-2008 08:37:20
JD may still offer the kit, but will likely be high $$$ by now. Should be simple to plumb in a power beyond control valve bought from some hyd. outlet store. On the 750 ( I think it should be almost the same ) there are 2 ports on the front of the rockshaft housing you remove plugs from. Back inside one of the holes it is threaded for a small plug to block off a passage. One hose goes from here to the valve inlet and the power beyond from the valve returns to the other hole. The valve return oil dumps back into the tranny case through a fitting installed at another blank plug. The service manual for your tractor should show the proper places to hook up.
