G ROD BEARINGS
flyingjd
05-07-2008 08:07:12
I am rebuilding 47G bought last year and am needing to rebabbit the rods. Can a babbit rod be converted to an insert bearing rod? I know that 70 insert rods can be used but would like to convert my origional rods if possible.
Mike M
05-07-2008 09:27:45
 Re: G ROD BEARINGS in reply to flyingjd, 05-07-2008 08:07:12
There should still be places that can re babbit your rods. The nice thing about the babbit is it is more forgiving and you can keep them adjustable. If your crank has just been reground and is true then the inserts a nice way to go. I had a set of late B rods fitted for inserts and they worked out fine. They still had to have the thick steel spacer shim left in them to come out correctly. My machine shop Center Automotive in Akron Ohio had done this before and I did it upon their suggestion. It was alot less money than used rods or re babbiting.
