4020 Fuel Filter Bleed
Hired Hand
05-07-2008 06:39:41
I have a 4020 with the dual can fuel filter system. I took the screw out of the top filter and pumped the transfer pump, but I can not get fuel to come out of the bleed hole. The tractor still runs, but will there be a problem with so much air in the top filter?
Bob
05-07-2008 08:38:19
 Re: 4020 Fuel Filter Bleed in reply to Hired Hand, 05-07-2008 06:39:41
Was the engine stopped so the fuel pump lever was on the "low side of the cam"?
If NOT, pumping the primer lever doesn't do anything.
Mike M
05-07-2008 06:43:39
Yes I would think you will have a problem if any air is in the system.
