1947 JD B - Gasket Question
kmhendress
05-07-2008 06:31:45
1947 John Deere B
I am getting ready to pull the clutch and "clutch/gear cover" off the tractor, wondering if there is a place that I can order a gasket for it. As I am not sure that I can find gasket material that is big enough for the clutch/gear cover. Is there a gasket suppose to be on there? I looked in my repair book and none was mentioned, but figured that was an oversight.
Thanks!
Kevin :)
kmhendress
05-09-2008 11:39:35
 Re: 1947 JD B - Gasket Question in reply to kmhendress, 05-07-2008 06:31:45
Thanks for all of the assistance, I was able to find the gasket online at jdparts.deere.com so now can order if when I need it!
Thanks to Pat, as I was able to find the parts manual online as well!
kmhendress
05-07-2008 09:23:51
 Re: 1947 JD B - Gasket Question in reply to jgc389, 05-07-2008 06:31:45
Not sure how to write someone...
Here is my email: [email protected]
Thanks!
Kevin
kmhendress
05-07-2008 09:22:42
I'm talking about the large cast iron cover that has the clutch and belt pulley mounted to it.
Sorry for not being specific enough.
Mike M
05-07-2008 09:33:39
 Re: 1947 JD B - Gasket Question in reply to kmhendress, 05-07-2008 09:22:42
Sounds like Maark has you covered.
kmhendress
05-07-2008 09:15:57
 Re: 1947 JD B - Gasket Question in reply to powertech84, 05-07-2008 06:31:45
PBrowning said: (quoted from post at 08:55:34 05/07/08) The only way to obtain parts for your tractor -- including gaskets -- is to use the Parts Catalog and identify the gasket by part number.
Once you have the number, a first call should be made to your local Deere dealer, and then go from there.
If you need help getting "grooved in" as relates to the Parts Catalog, write me -- I will guide you!(PatB)
Pat - I do need some help getting "grooved in" in regards to Parts Catalog.
I will try to send you a message....
Thanks,
Kevin
Maark
05-07-2008 09:08:41
You will need B154R 1st reduction gear cover gasket and B1855R clutch fork bearing gasket.
PBrowning
05-07-2008 06:55:34
Mike M
05-07-2008 06:42:13
I'm not totally clear which cover you are referring to ? The outer tin dust cover that is removed to get at the clutch adjustment bolts has no gasket. The pulley dust shield which is behind the clutch assy. has a gasket. The reduction gear cover which is the very large cast iron cover attached to the main case has a gasket too.
