Dust cover in clutch on 50
gitrib
05-07-2008 05:27:31
We are putting a new clutch in our 1956 model 50. we are checking the gear reduction. We have notice the Dust cover does not have s seal in it. The parts manual says "Dust cover seal". Do not know if there is suppose to be a oil seal JD does not have part. The manual also calls for a seal on the shaft by the roller bearing on the clutch drive shaft. Our tractor has that seal and we were going to replace it JD says "Unavailable". It is still in tractor we have not removed it. Is ther supose to be a oil seal in the Dust Cover? If so is it rubber,felt. or what? Come on Mike help us out.gitrib
Mike M
05-07-2008 07:07:48
 Re: Dust cover in clutch on 50 in reply to gitrib, 05-07-2008 05:27:31
I don't have my books handy to see what terms they use in the book. But I seem to recall the book calls a piece inside the pulley assy. behind the roller bearing in the pulley an oil seal when in fact it is just a stamped tin washer with a lip on it,more of a baffle or deflector to me not anything like what one would think of as an oil seal. This rides over the engine crankshft end. I also think they call the tin piece behind the belt pulley bolted to the reduction cover, with bolts that are to be saftey wired,a dust cover or oil seal ? this piece does have a gasket behind it where it mounts to the red. cover as it collects oil in the groove in it and sends it back into the red. cover. This part if removed also NEEDS to be centered by leaving the bolts snug and trial fitting the pulley and the tap around that shield until it doesn't rub the pulley then tighted up the bolts and saftey wire them. Hope this is clearer ?
gitrib
05-07-2008 10:31:50
 Re: Dust cover in clutch on 50 in reply to Mike M, 05-07-2008 07:07:48
Mike I went back and checked the parts catalog and it is part AB4368 Shield dust,with oil seal. It is unavailable from JD. I checked the JD service manual and it is refered to as dust shield oil seal. I can see no oil seal on the part. It does have a square grove with weep hole you mentioned. I cannot find any trace of a oil seal. I will get son to take a picture to send tonight. you are right on the other seal it is just a flat washer. If the dust shield is suppose to have some sort of a oil seal and we can get a idea of wher and what it is made of maybe we can be creative. Thanks
Mike M
05-07-2008 11:21:23
 Re: Dust cover in clutch on 50 in reply to gitrib, 05-07-2008 10:31:50
No oil seal in the dust shield just a gasket where it mounts onto the reduction cover. The operating sleeve in the back of the pulley has grooves on it to sling the oil off and this oil collects in that groove and drains out that hole. Early tractors like unstyled B's just drained on the ground later stuff returns it into the reduction cover. Make sure if you pull it off you recenter it so the pulley doesn't rub it.
52aojd
05-07-2008 06:30:37
Need info on the "50" clutch while I see this question. Is there any way to replace the spring clips that hold the clutch cover, without removing the whole thing? My clips are gone, need to rivet in new ones. Thanks. Not trying to cut in on your question.
Mike M
05-07-2008 07:13:46
 Re: Dust cover in clutch on 50 in reply to 52aojd, 05-07-2008 06:30:37
I suspose where there is a will there is a way.
I have always done them with the pulley off.
I would think that you could do them on the tractor if you can get the old rivets drilled out from the out side and then you may need to use stove bolts instead of rivets to hold the new clips in place as I think it will be about impossible to get it riveted on there as it is pretty hard off of there on the B and 50 with that very small dia. pulley.
gitrib
05-07-2008 08:15:09
 Re: Dust cover in clutch on 50 in reply to Mike M, 05-07-2008 07:13:46
We replaced these spring clips. Got them from JD. Got two different length of rivet. No way to back up to rivet while on tractor. We tack welded the end of rivet with mig and polished it off. Worked well.
52aojd
05-07-2008 15:42:26
 Re: Dust cover in clutch on 50 in reply to gitrib, 05-07-2008 08:15:09
Thanks for the response on the Dust cover on the 50. Welding seems to be the way to go to eliminate pulling it all apart. I did not know how hard the rivets were to peen. Brake rivets are not to bad. Thanks for the replys-----
