JD 1530 injector pump
Tia
05-06-2008 19:07:02
We just had the injector pump rebuilt on our 1530 and its hard to crank when its cold. Can anyone tell me what the specs are on the injector pump. Thanks for your time !!
jdemaris
05-07-2008 05:40:06
 Re: JD 1530 injector pump in reply to Tia, 05-06-2008 19:07:02
What specs? And by hard-cranking - do mean it turns over slow - or do you actually mean it cranks over fine but does not start well?
I ask since the pump settings will not affect cranking speed.
1530 should have either a JDB331AJ2681 Stanadyne pump or a JDB331MB2798.
Specs are: Timing mark on pump etched on at 183.5 degrees.
Roller to roller setting for fuel delivery setting is 1.979"
Automatic timing advance - (at engine degrees and RPMs) - 2 degrees BTDC at 1000 RPM, 10 degrees BTDC at 1600 RPM, and 15 degrees BTDC at 2150 RPM.
Minimum cranking-speed fuel delivery (this effects starting) - 42 ccs per 1000 strokes at 150 engine RPM.
