730 Gas Smokes
Bigblock
05-06-2008 18:46:57
My wore out 730 gas normally cranks and runs all the time without any oil (blue) smoke.Today I crank it and it smokes (blue) like a tar kiln.Why?
Bigblock
05-07-2008 18:22:51
 Re: 730 Gas Smokes in reply to Bigblock, 05-06-2008 18:46:57
I don't know, I fired it up today and no smoke!It's back to normal for now.It really needs to be rebuilt but it cost too much.It's 6.045 already so it will probably need to be sleeved and brought back to standard.BTW it is way worn over 6.045.Oil must have leaked past the non-existant valve stem oil seals.
DONMYEIL
05-07-2008 14:38:32
If this suddenly just happened the fuel pressure shut-off has probably got a diaphram leaking oil into the gas system. Used to be a common thing.Look at the color of gas in the sediment bowl.
Mike M
05-07-2008 04:26:25
By what you say " my wore out 730 " makes me believe what you say that it is indeed worn out. Those later 20-30 series 2 cyl. are hard on piston rings when well worn the bust them into little pieces and they can even work up past the piston and get hammered into the cyl. head. I would also agree with the others that say check for an air cleaner restriction.Also check to see if the oil is way overfilled/diliuted in the engine.
BushogPapa
05-06-2008 19:40:01
Drop the air filter oil cup and try it again.
If there is any obstruction in the oil cup or inlet tube to the air filter, they will be eliminated.. Is the oil OVER Full..?? (Fuel in oil)??
Let us know what U find..!!
Ron.
RobMD
05-06-2008 18:52:12
Guess your rings must've gotten stuck.. or broke.
