Engine Noise
NewBoyUpNorth
05-06-2008 17:14:05
I have a John Deere lawn tractor with a B&S engine that is about 2 years old. It was bought new, runs about 1 hr / week year round (mowing and snow blowing). Oil is fine and is changed 2x/year. This is the second time I"ve had it out this year and it started making the "clicking" sounds in the linked video after about 15 minutes. Any ideas?
Drew
05-07-2008 10:47:53
 Re: Engine Noise in reply to NewBoyUpNorth, 05-06-2008 17:14:05
Does that engine have hydraulic lifters? If it does, maybe a lifter is bleeding off and creating excessive valve lash???
BushogPapa
05-06-2008 19:44:26
If not shrouds are rubbing, I guess it is never a bad idea to check valve (tappet) settings..!
Remember, never set them "Tight"...!!
Ron.
jd b puller
05-06-2008 19:13:59
Videos can be misleading, but that doesn"t sound right. Is the noise coming from inside the engine or outside?
Pull booth spark plugs and roll over by hand. Possible places for interference would be the flywheel magnets to the coils (outside), or possibly the stator to the magnets on the inside of the coil. Either way, it sounds like if you ignore the problem, you"ll find out what it is and need a new engine.
About how many hours are on it?
M w J
05-06-2008 18:56:38
About a year after I got mine I got a letter from john deere that said the noise like you are hearing is normal and no cause for alarm. It said it was valve train noise and to be sure to use 30 wt. oil in hot weather. Mine is noiser for about the first 5 minutes of operation.
Bigblock
05-06-2008 18:41:31
If it has a Kohler engine you can expect ticking and smoking,but nothing is wrong with it.
JD Antique Acres
05-06-2008 18:01:44
I listened to the video and this is just a thought.... the sound that I hear sounds a little like the flywheel/and or guard, rubbing on the shroud..???
Walt in Jaxn Tn.
05-06-2008 21:11:21
 Re: Engine Noise in reply to JD Antique Acres, 05-06-2008 18:01:44
Has anyone suggested that it might be an exhaust leak? I"d get a small hose like a big rubber fuel line or a small garden hose (people throw away a lot of garden hoses this time of the year) about three ft. long, put it to one ear and the other end to suspected places around the engine. If the noise is external, you"ll hear it that way. --Walt--
