2840 hi low
pjbrown vt
05-06-2008 16:46:53
I think I know the answer to this question but here goes it..... My 2840 when it get warn and I flip the high low shift on the dash to low it makes a whinning noise and than it grabs. It acts like it slips for a bit in low. Any ideas ??? Bad clutch disks or internal leak?
Resting Relics 1
05-07-2008 04:35:33
 Re: 2840 hi low in reply to pjbrown vt, 05-06-2008 16:46:53
Hi PJ, From my days working as a mechanic for a Deere dealer during the 80's we saw many issues on the 2040 up to the 2940s with broken and cracked supply tubing to mostly pto's but also hi/lows on tractors so equiped. Unfortunately when these lines failed the result was burn't out clutch packs in the pto and hi/low. So your probably going to have to go in and fix the result but throughly inspect these tubes while your in there and check pressures before you pull it apart. Good Luck John
Tx Jim
05-07-2008 04:00:36
 Re: 2840 hi low in reply to lee wenzel, 05-06-2008 16:46:53
pj
I think you need to pull tin cover over transmission and check pressures on hi-lo. Those models are known for getting leaks in the tubes that feed hi-lo & pto clutches. I think it should read 160/175 psi.
