38 JD A overdrive
Vern H
05-06-2008 16:19:12
I dragged home a 38 JD A parts tractor to complement the 35 A I`m tinkering with. While exploring my treasure I found a strange contraption behind the flywheel. I was told it is a Behlen OD. Tain`t so. It appears to be a shop built OD unit that shifts using the main stick instead of a lever on the side box. The builder drilled the trans casting and extended the second gear rail into the OD box. Any one seen one like it? Thanks, VH
Vern H
05-08-2008 16:31:22
 Re: 38 JD A overdrive in reply to Vern H, 05-06-2008 16:19:12
OLTWOPOP, Thanks for the great wisdom! The 38 parts tractor is missing only the cyl. block , head & pistons, so if I decide I need a JD A with an OD I`ll start looking for parts or maybe sell it as is. Thanks again. VH
OLTWOPOP
05-06-2008 20:06:01
Vern H,
Sorry about my reply after rereading your post I see it's not the same as mine. If it shifts off the main lever and does't have a lever on the box its self, Again I'm sorry.
Vern H
05-06-2008 20:59:21
 Re: 38 JD A overdrive in reply to OLTWOPOP, 05-06-2008 20:06:01
OLTWOPOP, No apology needed at all. Thanks for the information. I wasn`t just sure how a Behlen worked. VH
OLTWOPOP
05-06-2008 19:43:33
Vern H,
I have one on a 1934 (A) you put the main shifter in neutral then shift the Behlen into gear and use the high low lever this gives you 5th & 6th gear I'm guessing maybe 12 to 15 mph in 6th and 8 to 10 in 5th. I have never clocked it. I would not put one on a tractor with steel wheels it would be unsafe in my opinion.
Vern H
05-06-2008 20:16:36
 Re: 38 JD A overdrive in reply to OLTWOPOP, 05-06-2008 19:43:33
OLTWOPOP. Keen handle! Thanks for the reply. You must have a real Behlen. To shift this one you use the main stick. OD is just opposite 2nd gear. Are the trans shafts and gears the same in a 35 and a 38? The castings are not the same with the different oil pump placement. Thanks, VH
OLTWOPOP
05-07-2008 19:36:32
 Re: 38 JD A overdrive in reply to Vern H, 05-06-2008 20:16:36
Vern H There are changes and improvements made in the trans. between 1935 & 1938 the main case was changed at #424025 this was the 1st 1936. In 1937 they changed the speed on the high side slowing them down in 3rd & 4th this started at at 450503. So your 1935 will be faster in 3rd & 4th than your 1938. Some of the gears and shafts are the same from 1934 clear up into the styled models. I have a parts book showing this. Now I bet you're wanting to put that O.D. out of the 38 into the 35 you might be able to, But it will be ALOT of work. I also have a 1937 A that 30 years ago I turned the high range gears 180 degrees inside the trans. for tractor pulling this slowed it down to about 1.5 mph. At that time I used parts from 1935 to 1942 to do it. Looking back on it now I wish that I would have never done that. I'd like to put the gears back to stock, But its is alot of work pulling the gears out of an old John Deere.
