1020 won't run until next day after running out of gas
Scott Robbins
05-05-2008 19:40:39
I am new to the tractor world and have had a jd 1020 for about a year now. Every since I owned it if I let it run out of gas and then tried to fill it back up and continue working it will not run. It will start and then die, start and then die. But if I quit and come back the next day it starts right up and runs fine without doing anything to the tractor. It"s like it is fixed by just waiting a few hours. Any thoughts to the problem or solution would be greatly appreciated.
Scott
garytomaszewski
05-05-2008 20:09:31
 Re: 1020 won't run until next day after running out of gas in reply to Scott Robbins, 05-05-2008 19:40:39
What happens if you don't run it out of fuel, but shut it off and then try to restart ? Could be a problem with the fuel solenoid sticking while hot and dry or dirt floated around by refueling.
Scott Robbins
05-06-2008 13:52:51
 Re: 1020 won't run until next day after running out of gas in reply to garytomaszewski, 05-05-2008 20:09:31
You can shut it off while hot all the time and it starts right back up and runs normal. It is only when it runs completely out of gas. We try not to let that happen, but you know...
garytomaszewski
05-06-2008 15:58:08
 Re: 1020 won't run until next day after running out of gas in reply to Scott Robbins, 05-06-2008 13:52:51
Well aware of the running out of fuel problem, mine always happens trying to get in before the rain hits or as far away from the fuel barrel as I can be. You might try some fuel injector cleaner in the tank, but I'm still leaning toward the solenoid sticking, especially when you say it will start if you shut it off as opposed to running dry.
RobMD
05-05-2008 19:54:33
trash in the gas tank, take screen and pipe out of tank and wash tank out.
Fuel solenoids were a common problem with these, but in your case, there might be gum buildups on the internal parts of the carb.
