1010 Plug Fouling
Vermont John
05-05-2008 16:04:46
I have a 1963 1010 gas. The plugs foul in a matter of HOURS. I rebuilt the carb, timed it, I have compression. I am running Autolite 216s. I owuld like to try a hotter plug, but the local parts people do not know which plug I can use. I am thinking of going to electronic ignition, but do not want to waste my time and money, just like everything else I have tried. Any help would be appreciated.
buickanddeere
05-06-2008 05:15:46
 Re: 1010 Plug Fouling in reply to Vermont John, 05-05-2008 16:04:46
Autoloite makes a 473 which is a hotter non resistor plug. When at it, toss the resistor plug wires away and install solids.
If the coolant temp isn't 195F the plugs and combustion chambers run too cold and causes fouling. Most old equipment has had the thermostat removed by some tinkerer. Too rich an idle and main mixture causes fouling as well.
Vermont John
05-06-2008 07:22:00
 Re: 1010 Plug Fouling in reply to buickanddeere, 05-06-2008 05:15:46
I bet that the thermostat has been removed. It does seem to run cool. I will try the hotter plug, too. I think my mixtures are ok. I just rebuilt the carb. There is no visable smoke any more.
CPeter
05-05-2008 19:01:13
Tryt adding another washer or two under the plug. That will make it run hotter and may help you fouling problem. I use Champion H12 witgh 2 gaskets on my Dubuque tractors and that combo works for me.
CPeter
Vermont John
05-06-2008 03:51:22
 Re: 1010 Plug Fouling in reply to CPeter, 05-05-2008 19:01:13
Thanks CPeter. I'll try the two washer kit. A guy at the parts store told me about anti-fouling adapters that raise the plug out of the chamber to make them run hotter. I have not tried them though.
Roy in georgia
05-05-2008 17:30:44
is it oil or gas causing it to foul? you should be able to tell then look at that maybe just the crank case ventilation stopped up. does it smoke? what color? how much?
Vermont John
05-05-2008 18:18:55
 Re: 1010 Plug Fouling in reply to Roy in georgia, 05-05-2008 17:30:44
It is not smoking at all now that I rebuilt the carb. I checked on the web. It looks like carbon fouling. The crank case is vented.
Roy in georgia
05-05-2008 18:51:39
 Re: 1010 Plug Fouling in reply to Vermont John, 05-05-2008 18:18:55
it was suggested to me to run 1 quart of transmission fluid in 5 gal of gas to loosen carbon build up that may help it breath better. you still may be getting oil in there causing the build up. I bet you are and you are running it lean. a rich burning engine is better than a lean engine, play with that carb some then maybe you will see that white oil smoke.You may know exactly what you are doing and these are just my opinions hope they help even if just to make you think of something you haven't yet. I wish I could figure my 1010 out it drove me nuts for about 2 months so I let it sit for a while till I am heady to pull the rest of my hair out. I have 2 other tractors now so it can rest but at the time it was the only one I had.
Vermont John
05-06-2008 03:49:17
 Re: 1010 Plug Fouling in reply to Roy in georgia, 05-05-2008 18:51:39
Roy, I know what you mean about a 1010 driving you crazy. I bought mine from a Kubota dealer, who said that the engine needed to be rebuilt and had no compression. He said that was why it was hard to start. However, he must have been thinking diesel-type compression. I checked it and it is fine. With clean plugs, it starts just fine. I had black smoke until I rebuilt the carb. Not it runs clean. I'll try enriching the mixture a bit. I'm also going to try CPeter's idea of an extra wather or two. I have heard of that transmission fluid approach, and I may give it a try. I am told that transmission fluid has a ton of detergent in it, and that is why it helps.
