530 carburetor
Bob And
05-05-2008 14:52:57
I'm working on a neighbor's 530 tractor which he says hasn't been started for almost 2 years. I am not experienced with John Deeres so when I started making sure there was gas in the carburetor I found 2 things that I'm not familiar with. The first is like a poppet valve that has it's stem sticking out the top of the sediment bowl and inside the bowl is a small valve which opens when you push down on it and gas drains into the bowl. The second item is two small (like 1/8") lines that run from the upper part of the sediment bowl. One runs to the block, the other runs up behind the instrument panel. Would someone be so kind as to explain the purpose of these two items to me? Thank you so much.
MLD
05-06-2008 05:55:01
 Re: 530 carburetor in reply to Bob And, 05-05-2008 14:52:57
I concur with Bigblock, sounds like a great discription.
Bigblock
05-05-2008 15:10:52
Those are oil lines one goes to the guage and one to the sedemint bowl they are fed by the connection at the block.Oil pressure opens the sedement bowl valve to permit fuel flow.And lack of oil pressure closes the valve ,just so you dont have to close/open the petcock when you get off and on the tractor.
Pete in MD
05-05-2008 15:07:55
If you have oil pressure when the engine starts the valve opens and the engine continues to run. If the oil pressure is too low the engines dies.
Bob And
05-05-2008 15:43:05
 Re: 530 carburetor in reply to Pete in MD, 05-05-2008 15:07:55
All right!!! That's a great idea isn't it? Thanks so much guys. I really apprecicate your help.
RobMD
05-05-2008 16:03:23
 also... in reply to Bob And, 05-05-2008 15:43:05
In addition, the "poppet valve" as you said will prime your carburetor with gas when you've run out of gas. ALSO - not only does it keep the tractor from running with no oil pressure, but it also keeps the carburetor from flooding out due to a sticky needle valve and seat.
