I Finally Did It--# 1Unstuck
Bob Landers
05-05-2008 14:17:43
Thanks to the good advice from this board's archives, I got #1 piston unstuck on my JD B (239164). It went grudgingly. I pulled the head, took a 4.5 OD heavy pipe and banged it with my heaviest sledge hammer. This was after soaking it for 4 months with PB Blaster. I had disconnected the rods and took #2 out first--it came out pretty easy. My problem now is getting #1 out. Even tho it's unstuck, I moved it back about 2 inches, it's still hard to move. Any advice for a novice would be appreciated. Thanks.
Bob Landers
05-06-2008 18:21:28
 Re: I Finally Did It--# 1Unstuck in reply to Bob Landers, 05-05-2008 14:17:43
Didn't do the fire remedy--block still on the tractor. Went out today and found a honer. Now I've got to remove the ridge and then hone. I'm concerned about getting the piston out the front since it's still hard to budge. Current plan is to remove the ridge, hone and move the piston out using the crankshaft. cylinder is not badly pitted.
Bigblock
05-06-2008 15:09:39
Did you try the fire trick?
Bigblock
05-05-2008 15:17:14
Asuming you moved the piston down the bore you can hone the rust out of cyl above the piston,that should help a lot.
