JD 4020 plug fouling problems
groller
05-05-2008 13:44:12
My 4020 fouls out number 2 and 5 plugs and they don"t work at all. The other ones seem fine. Compression in all cyl. is 125-126. I checked the spark and all is good there and it is firing at the right time. If it was the carb wouldn"t other cyl. foul out? I am going to rebuild the carb anyway but I have it all pulled apart and am ready to remove the head to see what is going on but first I thought maybe someone else has an idea. I appreciate any help.
Heat Houser
05-05-2008 19:31:06
 Re: JD 4020 plug fouling problems in reply to groller, 05-05-2008 13:44:12
I use Champion D21 plugs (hot) in my 4010 gasser during the winter. The plugs won't foul but in a hard pull, the electrodes glow red and will cause backfiring thru the carb as it sucks the gas in thru the intake valve. I change to colder plugs in the spring/summer to prevent this.
teddy52food
05-05-2008 18:47:19
2 and 5 are running mates. Are you sure the wires in the cap are right? 153624 Did you try new plugs of another brand? Are they hot enough?
buickanddeere
05-05-2008 13:49:48
Worn cam/follower(s), broken piston rings?
groller
05-05-2008 15:38:54
 Re: JD 4020 plug fouling problems in reply to buickanddeere, 05-05-2008 13:49:48
2 & 5 compression are the same as the rest 125-126 psi. I did have gas in the oil but not water and no oil in the radiator. It starts right up and I hear no engine noises such as grinding, tapping or tinging. Just popping from only running on four cyl.
