JD 310B differential housing
Bill Booth
05-05-2008 12:01:24
I have a well used 310B that has been worked hard. I have been doing repairs since I bought it (replace hoses, fuel injector pump, welding, ect..) My latest task is what seems to be a repaired crack in the rear differential housing. It appears that an area in the housing had an epoxy (JB weld?) slatherd over a area near the rear tire hub. I now have a steady drip - approx every 10 seconds - that seeps from this epoxy area. I assume that this is just from the differential reservoir, not under pressure. The hope is move the backhoe approx. 100 yards to a level area and elevate the rear and stop the leak. I do not use the backhoe very often, so the plan is to clean the area and apply more JB weld - am I correct in trying this as a repair? I also need some direction as to where to add the fluid and type (if it is not the standard tractor hydraulic type).
Roy Suomi
05-05-2008 13:56:42
 Re: JD 310B differential housing in reply to Bill Booth, 05-05-2008 12:01:24
I choose to not do "repairs" using liquid steel..It will eventually bite you in your behind..Not to say ruin any reputation that we would have built up over the years..As far as location of oil filler..It's on the floor next to the diff lock pedal..And you are correct in assuming it's not under oil pressure..I , myself would locate a used axle housing , and rebuild it as it should be..I'll bet the old owner never greased that elusive grease fitting behind the wheel hub..Not many know of these fittings..If it's never been greased , you will find a square headed plug on the top of the axle housing..Take it out and install a 90 degree grease fitting and pump about half a tube of premium high temp grease into each axle housing...
