4230 cab on a 4040
DRC9723
05-05-2008 09:02:03
Has anyone installed a sound-gard body from a 4230 on a 4040 open station? I've done some research, from looking at the parts catalogs, it looks like it should work. The dash cowels are the same, the hood heights are the same, cab mounts looks to be interchangable. Just curious if anyone has had luck with this type of transplant? Thanks in advance...
WTW
05-05-2008 11:06:51
 Re: 4230 cab on a 4040 in reply to DRC9723, 05-05-2008 09:02:03
The most important thing that will be an issue is what your 4040 is: Is your 4040 an open station Fender Deck or is it a Four Post Roll Guard? The 4230 cab will fit your 4040 Four Post tractor allot easier than it will fit a open station fender deck tractor. The reason being the open station Fender Deck tractor will not have the needed cab mounting holes in axle housing to mount cab to. To get the needed mounting holes the axle housings would need to be changed. The Four Post option would have these mounting holes. If your 4040 tractor is a Four Post, 4230 cab will fit. The front cab mounts would need to be added as the Four Post mount did not use the rubber isolation mounts. If your tractor is a fender deck model and you still plan on converting it I would be interested in your fender deck assembly. If you are looking for someone to do this swap I would also be interested in doing it for you if your not. Located in Eastern Iowa. Thanks, DW
DRC9723
05-05-2008 11:41:22
 Re: 4230 cab on a 4040 in reply to WTW, 05-05-2008 11:06:51
DW,
The 4040 is an open station fender tractor. I don't have the tractor here yet, so I can't tell if it has the holes for the rear cab mount. But from what I can see in the parts catalog, it looks like the 4040's all used the same axle housing no matter what configuration (SGB, 4-post or fender deck). The 30 series axle housings definately didn't have the holes for the cab mounts on an open station tractor though. Any other problems that you know of that I might run into on the open station 4040?
Thanks for your input...
P.S. I'm planing on doing the work myself and I already have a home for the fender deck.
WTW
05-05-2008 13:19:05
 Re: 4230 cab on a 4040 in reply to DRC9723, 05-05-2008 11:41:22
If the holes are in the axle housings for cab mounts you should be ready to go. The Fender Deck and Four Post models tractors do not have an attenuator in the hydraulic circuits that all cab tractors have. This is nothing more than an hydraulic muffler to reduce hydraulic noise that may transmit into steering and brake control valves and lines. The attenuator hangs on the back side of the front right hand cab mount. It will work without it but you may notice some hydraulic noise in cab. The only other thing that I know that you will have to change is: Center console is bolted to top of clutch housing, bolts and spacers will have to be removed as console will be bolted to cab floor and be isolated from chassis. Console will become part of cab floor and will not be connected to clutch housing or transmission. Brake and differential lock lines are also different as non cab models use solid steel line that will need to be changed to high pressure hose and shorter lines to allow cab to move without breaking lines. Side console sheet metal cover is also different than open station sheet metal. Shift control supports will have to be removed from shift controls and controls will be mounted to cab frame. There probably is some more but these are some things that come to mind. Been there and done many. Good Luck, DW
Mike Aylward
05-05-2008 09:08:39
DRC, there is much more to check than just the compatibility of the shell. Look to see if linkages, gauges, etc. are the same. I am not saying it won't work but do your homework. I once helped put a 30 series cab on a 40 series four wheel drive tractor and there were many, many small things not the same. It could be different with a row crop tractor but odds are a cab from your series of tractor would be easier. Just something to think about. Mike
DRC9723
05-05-2008 09:36:32
 Re: 4230 cab on a 4040 in reply to Mike Aylward, 05-05-2008 09:08:39
I was planing on the leaving the complete steering column and dash assembly on the 4040, just installing the cab over it. From looking in the tech manual, on the early 40 series, the dash and steering column stay with the tractor when you remove the cab. Maybe there are more things to look for, but if i'm leaving the dash in place, I don't think there should to be too much hassle. Maybe its just wishful thinking?
