Deere 310C Hydraulic Filter Warning Light
David Grant
05-05-2008 06:38:06
I keep getting a hydraulic filter warning light at about 1500 rpms which usually goes out once the machine is warm and has been used. Lately the light has been staying on at lower rpms whether it is warm or not, so I decided it was time to change the filter. Changing the filter has done no good, so I went on to the screen in the resevoir; which was also pretty clean to start off with. The light still comes on when cold and at higher rpms when warm, but I'm not sure what to do now that I have a new filter and clean screen. Does anyone have any experience or advice on this problem? Is this a fairly normal thing on an old machine, or am I in danger of causing real damage if I let this continue?
Roy Suomi
05-05-2008 13:59:47
 Re: Deere 310C Hydraulic Filter Warning Light in reply to David Grant, 05-05-2008 06:38:06
You either have a weak sender unit or are using the wrong oil..Possible viscosity difference..Use Hy-Gard or equivalent oil..
David Grant
05-06-2008 05:00:34
 Re: Deere 310C Hydraulic Filter Warning Light in reply to Roy Suomi, 05-05-2008 13:59:47
When you say weak sender unit, are you talking about the actual hydraulic pump or something else? How can I test to see if the sender unit is functioning properly?
