3010 D Electrical problem cont.
MaverickM23
05-05-2008 03:51:39
I posted on here last week about my 3010 Diesel having some electrical issues, mainly the circuit breakers clicking upon shutdown. I checked the starter and generator for buildup which might be causing it to ground. Then I hooked it up polarized the generator and fired it up. It ran alright but when I tryed the lights only the right side worked, plus the dash light got really bright for a split second then went out. The generator light comes on but when it goes out it suddenly becomes very bright then goes out. Then once I shut down the tractor the circuit breakers start clicking again. I looked and the voltage regualtor breaker on the BAT side are closed once the tractor is turned off. This system is driving me nuts. Im considered changing it to 12 volt but want to make sure I"m not missing something before I spend that amount of money.
Bob
05-05-2008 08:25:34
 Re: 3010 D Electrical problem cont. in reply to MaverickM23, 05-05-2008 03:51:39
Have you considered the possibility of a "bad" circuit breaker?
Gerald J.
05-05-2008 08:21:22
Check the mid battery ground wire.
Gerald J.
MaverickM23
05-05-2008 13:38:53
 Re: 3010 D Electrical problem cont. in reply to Gerald J., 05-05-2008 08:21:22
I have considered it being a bad breaker. I priced them at 51.00 a piece. Would that cause the regulator point on the BAT side to close upon shutdown though? When you say mid battery what are you referring to? I have checked the batteries and their cables all seem good. Right side positive to the starter, left side negative to solenoid, right side negative to left side positive then connected to chassis ground through fused line. Not sure why I blew the lights out though
