8430 lost prime
lpsswiss
05-05-2008 02:01:05
I have an 8430 that eill stall out when in use, the fuel primer pump was just replace a shot time ago. I replaced the filters and a line that had aleek in it. But the tractor will run for a while (10 to 30 minites) and then lose prime and quite. have to crack the line prior to the injector pump and pump the fuel pump. It will start and run then. any ideas?
twopop
05-05-2008 04:58:38
 Re: 8430 lost prime in reply to lpsswiss, 05-05-2008 02:01:05
suspect something in the fuel tank that is cutting off the supply of fuel.think you need to clean the tank
