430 high idle
Richard Chishol
05-05-2008 01:47:22
Im sure I read somewhere that high idle in a late 430 should be 2100 rpm. I cant get more than 1800 out of mine ( ser no 159406). Is this governor adjustment ( Ive done everything the manual says) or timing perhaps?
Mike M
05-05-2008 05:03:55
 Re: 430 high idle in reply to Richard Chisholm, 05-05-2008 01:47:22
Can you get enough travel on the throttle lever ? May need to tighten it all up ? Got the set screw backed off down by the gov. linkage assy. ? You may just need a NEW spring on the gov.arm to pull it tight enough.
