1961 John Deere 2010 hydraulic system
GeorgiaHayFarmer
05-04-2008 14:32:24
Hello to all,
I'm currently working on a 2010 Diesel hydraulic system and having some inconsistencies with the lift. I have it set up for parallel operation and notice that unless I move the inner selector lever beside the seat slightly forward from the #1 position the lift will not raise with a load on it. The load/depth is set in the center detent. When I move the selector lever slightly forward, it will raise about 500 lbs on the end of a boom pole, so I don't believe I have a week pump issue. I have not replaced the hydraulic filter yet. Does anyone have experience troubleshooting this system that could offer some advice. I have the service manuals and have been reading through them carefully. I suspect I have a linkage adjustment issue or a worn selector lever linkage.
Thanks,
Scott
