830 Electric start ring gear
toolz
05-03-2008 19:28:14
Well my ratty old 820 is back together- fixed the differential, fixed the axle bearings, replaced gauges, etc. The tractor was converted to electric start (badly) when I got it, so it has a new proper starter, two big new batteries, and all new 4-0 cables. It spins over great (much better than I expected) and starts right up. The problem is the starter drive and the ring gear aren"t getting along at all. The ring gear is apparently for pony start, and I assume the tooth pitch must be different? Sooo, I guess I need an electric start ring gear from an 830. Does anyone have one to sell me? I"ll take used or new, whatever you got. Or is there a starter drive available that has a wider tooth pitch?
Any help would be appreciated. This old tractor ain"t pretty, but it"s functional again, except for this problem. Thanks- Kevin
