28 D Magneto
Matt
11-02-2003 21:26:49
We have a 28 or 29 D (the year is a debate between my dad and brother)It is all there but the mag,What mag belongs on her?She has been waiting in the corner of our shed for years its time to hear her run.Unfortunally shes stuck now when we where kids we turned her over quite a bit but somewhere along the line she froze up,Do we need to pull the head off or try another route first?
Duane Larson
11-02-2003 21:41:33
 Re: 28 D Magneto in reply to Matt, 11-02-2003 21:26:49
Matt,
It would be good to check your serial number (and verify the year), located on the transmission case where the spring seat joins the case. If your D s/n is below 81069 it came with a Splitdorf 246C magneto, and from 81070-130699 it had a Splitdorf 246T magneto. The main difference is the C had brass sides and cover, while the T had pot metal sides and cover.
Since it used to turn over, and has been shedded, you might first pull the valve cover (under the front of the radiator) and see if the valves are free. If they are, some ("gentle")tugs on a pipe chained to the flywheel may break it loose. If the valves are stuck, you want to remove the pushrods so something doesn't get broken when trying to turn the engine over. From there you are into decisions about how to loosen up a stuck engine - the archives has a lot of info re that problem.
Matt
11-03-2003 22:58:31
 Re: Re: 28 D Magneto in reply to Duane Larson, 11-02-2003 21:41:33
Duane,Thanks for the info and advice,Matt
