'49 B spark plugs
Mathias NY
05-03-2008 13:18:27
I am fouling plugs in my '49 B. Changing the rings isn't really an option right now. Is there a hotter plug I could switch to? Right now I am running Delco C88L's.
Thanks for the help.
buickanddeere
05-04-2008 11:34:45
 Re: '49 B spark plugs in reply to Mathias NY, 05-03-2008 13:18:27
Get the coolant temp to 195F as well.
Andy Motteberg
05-03-2008 20:53:11
Use Autolite 3116.
johns48jdb
05-03-2008 14:54:40
your carb is out of adjustment. its needs turning down a lot. try getting it cranked and adjust carb. i'd start out with turning them down several clicks right away before cranking.
Mathias NY
05-03-2008 18:16:53
 Re: '49 B spark plugs in reply to johns48jdb, 05-03-2008 14:54:40
Thanks for the tip, after I replace the plugs I will try leaning it out some. I hadn't considered the fuel mixture.
It does burn a considerable amount of oil though, so I will still try for the hotter plugs.
johns48jdb
05-04-2008 04:34:16
 Re: '49 B spark plugs in reply to Mathias NY, 05-03-2008 18:16:53
don't be surprised if nothing you do helps. if you remove the plugs and they are oil soaked you might as well tear it down and ring it.
Coltond202
05-03-2008 13:27:17
Iv been told to run autolite. The 3077 is sopposed to be HOT
