john deere anh
amo
05-02-2008 09:49:25
On a 1941 John Deere ANH what does the n and h tell about the tractor? I got a document from two-cylinder with the model number ANH. The rear axles hae been shortened some. Thanks Amo
d. coleman
05-02-2008 19:21:03
 Re: john deere anh in reply to amo, 05-02-2008 09:49:25
"N" means narrow or single front wheel and "H" stands for high crop which could be larger rear wheels or greater ground clearance. d. coleman
RobMD
05-02-2008 10:37:37
N means single front end
H means 42" rears.
Jake Winn
05-03-2008 08:42:51
 Re: john deere anh in reply to RobMD, 05-02-2008 10:37:37
Sorry, but H does not mean 42 inch rears. It means high clearance. On A's and B's it would be 40" or even optional 38" on some machines if you look in sales literature. On HWH and HNH tractors its 38" tires.
The late A and B tractors with 42" tires, they were just AN, BN, BW or AW high clearance, not ANH, BNH, etc.
AMO, does your tractor have a single front? Does the drawbar frame have a spacer plate between it and the rear axle housing? Does the rear axle housing have about a 3" gap between the outer bearing and outer implement mount?
These are clues of a ANH tractor
JW
