Hey robersw!
edj856
05-02-2008 09:39:28
How did you make out with the transmission? Find any other bad gears or just the synchro blocker?
robersw
05-03-2008 19:05:04
 Re: Hey robersw! in reply to edj856, 05-02-2008 09:39:28
Well, it is all back together and exactly the same as before. This time I am really going to wait to this winter before I take it apart again. I have no clue what else to try right now.
robersw
05-02-2008 17:42:06
Hey edj856
The only other thing I have found besides all of the detent balls being missing on the blocker was on the high range syncronizer drum. The front 3/32-1/8" of the gear teeth was rounded off all the way around. So basically I have all of the pieces to rebuild the high range syncronizer.
I still do not feel confident that this will fix my problem of not having 5th and 6th. Since 5th is in the low range, it just doesn't make since. But since I tore everything down and could not find something wrong with the actual 5th/6th speed gear/pinion assembly, all of my hope is in that part.
I know I told you a while back that I thought the clinking sound was from the speed range compartment. I have been thinking lately that since the high range syncronizer is so close to the speed change compartment, that it might actually be the problem. But then I think I am just trying to sell myself on this being the fix.
I plan on putting it all back together this weekend. Hopefully I will get it done. Got to spend some time getting the hay equipment ready for next week as well.
Thanks for the follow up. I will let you know the outcome.
Scott
