2010 motor into 1010 ?
Brian-Ont
05-02-2008 06:38:24
Have a 1963 1010 tractor with a serial # RU35454 with a 115 gas motor, motor shot. Found a 1961 2010 gas motor out of tractor with serial # R17567.I know I have to use the 1010 water pump (shorter in height). Also have to use 1010 water/thermostat housing again shorter in height as opposed to the 2010.The carb on the 2010 faces towards the front of the motor, so will have to build/alter the air breather tube to fit.
QUESTIONS 1) Will the flywheel fit of the 1010 on to the 2010?
2) want to use the throttle cable that the 1010 uses.Will the gvernor system bolt onto the 2010?
3) WILL THIS WHOLE PROJECT WORK?
Thankyou any input and help on this issue.
Brian
jdemaris
05-02-2008 15:08:30
 Re: 2010 motor into 1010 ? in reply to Brian-Ont, 05-02-2008 06:38:24
I know of many 1010 crawlers that got 2010 engines bolt in with no mods. No problems - just more power.
That 1010 115 c.i. engine is just about the same size as a 420 two-cylinder with 113 c.i. Just has four little holes instead of two big ones. It is pretty anemic - 1010 diesel is bigger and has better low-end torque even though it's rated the same horsepower. 2010 gas is the exact same size as the 1010 diesel - even uses the same sleeves.
robersw
05-02-2008 06:57:26
The flywheel is the same on both the 1010 and 2010. This should work fine with the mods you are already planning on.
As far as the 2010 not being a good engine. I like my 2010 and have no problems with the engine in it. And you know how it is, people like to complain about anything and everything.
usetabesteve
05-02-2008 06:50:51
People don't say good things about the 2010 engine but I have no personal knowledge of them. If you look at the specs for the 1010 Special, there's a combine motor that would work a lot easier. Maybe a model 45 combine?
Brian-Ont
05-06-2008 08:04:37
 Re: 2010 motor into 1010 ? in reply to usetabesteve, 05-02-2008 06:50:51
Thanks for the help and input.Will post it when its running and how the job worked out
Brian
