4020 remote leaks
J Heitkemper
05-01-2008 19:56:40
every now and then My 4020 leaks bad around the remote couplings ,, Is there a plastic roll in shim that needs to be renewd in these couplers ?,, what is the trick to installing them correctly ?,, Thanx Jim
zog
05-03-2008 20:05:18
 Re: 4020 remote leaks in reply to J Heitkemper, 05-01-2008 19:56:40
Teflon ring always goes to the outside of the fluid you are trying to seal. O-ring always towards the inside next to the fluid you want to seal. Use ether, carb cleaner or brakekleen and commpressed air to dry the o-ring groove. Very hard to install in a oil slick o-ring groove.
thurlow
05-02-2008 05:53:58
In addition to what the other guys have said, check the male/hose ends; they can get so worn that they'll leak.
ET
05-02-2008 05:19:07
Sometimes the leak is in the upper or lower o-ring that seals the locking lever shaft.
Deerehunter
05-01-2008 21:50:09
I worked at a JD dealership back in the 90's and one of the veteran mechanics told me the best way to get the o-ring and teflon ring in is to spray either starting fluid or carb. cleaner in the groove and wipe it dry with a clean cloth. This cleans and dries the groove out and prevents the teflon ring from working its way out. I take an o-ring pick with a 90 degree angle and push the o-ring back while working the teflon ring around. This has worked very well for me over the years and hopfully will work for you. Be sure to replace the 0-ring with the teflon ring. Good luck
Bob
05-01-2008 20:14:35
The teflon ring goes in OUTSIDE the quad ring. You have to say a few magic words, and set your jaw just right to get the stupid things to roll in there!
