520 clutch hub
Ross520A
05-01-2008 19:09:30
I purchased a 520 and had to go behind someone who done some clutch work on it, I noticed it had an aftermarket clutch hub on it,upon reassembly it seemed to have several marks on it, I basically picked the one that most looked like a good witness mark.How can you tell other than the mark if it"s wrong or right? It doesn"t seem to vibrate at high idle. THANKS IN ADVANCE!!!
turklilley
05-02-2008 18:49:44
 Re: 520 clutch hub in reply to Ross520A, 05-01-2008 19:09:30
Where do you put the graphite?
BushogPapa
05-01-2008 19:37:40
If it doesent vibrate BADLY, you have it on right..!!
I have to give my 520 clutch a good shot of powdered graphite about twice a year, or it gets really Grabby...
Anyone know why this one does and my '52 "B" has never been grabby..?
RobMD
05-02-2008 09:21:18
 Worn Clutch bolts... in reply to BushogPapa, 05-01-2008 19:37:40
Excessively worn clutch disk T-bolts.
What happens is that when you start to engage the clutch, the bolts twist around with the rotation of the crank. When they've reached the end of their "slop", they "grab" the disks and pull them in tighter, giving you that "jump" effect just before you snap the clutch in.
New bolts and toggles and clutch facings reduce this problem by as much as 85%.
buickanddeere
05-02-2008 06:28:44
 Re: 520 clutch hub in reply to BushogPapa, 05-01-2008 19:37:40
Excessive endplay can make a clutch grabby.
Kurt_JDB
05-02-2008 04:44:53
I had a very grabby clutch on my 51B. I also had a spline problem with my crankshaft and clutch driver disk. Problem went away when I fixed the spline problem. My theory is that if your splines arn"t perfect, the clutch driver does not go on exactly straight, and this will cause the clutch to grab. See the same problem in a car if you don"t replace or reface the pressure plate when you do a clutch job.
Might try sticking another clutch driver in there.
Kurt
Mike M
05-02-2008 04:26:57
I had a 50 with a grabby clutch. I tried alot of different parts in it and never could get it like I thought it should be. Most all my others were VERY smooth. I also heard about that graphite trick and it seemed to help it.
RobMD
05-01-2008 19:35:27
The originals had a "V" stamped on the spline where it matches up with another "V" on the crank... I do believe that aftermarket mans. should have followed suit.
