70 electrical question
johndeereman
05-01-2008 16:13:15
i just bought a 70 gas this is my first electronic ignition tractor so im sorta lost. First off its not charging ,it has a generator havent checked in to it yet, on the dash the swith has off i l b d im assuming i is for ignition and l is for lights but what is b and d for? do i need to have it swithed to one of these to charge? also how to tell if its wired for positive or negative ground?iv hooked it up both ways and it dont make a bit of difference if someone can tell me how to wire it for negative ground id appreciate it that would be my preference thaks in advance
55 50 Ron
05-02-2008 10:06:06
 Re: 70 electrical question in reply to johndeereman, 05-01-2008 16:13:15
How do you know it"s electronic ignition? As others have stated, it"s not the way to save money if you just jump in and try things without knowing for sure what you are doing. The cost of the proper manual will far-and-away be a good investment. If you know it"s not charging, then you had to have it running to figure that out and to get it to run the switch was (I assume) in the I position so that would tell you something I=ignition
Have you had it running since you switched the battery polarities? If you have, then you know it DOESN"T have electronic ignition, since as others have said the electronics would be damaged by polarity reversal.
buickanddeere
05-02-2008 06:36:05
Factory was + chassis return. Pertronix makes modules in both - and + chassis versions. As previously stated. #1 If in driving in new territory without a roadmap. You will waste time, money and resources. Educated guesses on the tractors are going to cost you extra as well.1-800-522-7448. #2 By trying both polarities it's guarantied you made the smoke leak out of the electronics.
GeorgiaHayFarmer
05-01-2008 19:33:01
If you plan on making this tractor right and want to make your time worth while then I would suggest getting a book on it. A John Deeere service manual will have the electrical diagram you need for reference. It is a great way to learn about the ins and outs of your 70. A lot of damage can be done to existing parts without a good reference manual. Ask me how I know... B is for bright and D is for dim if I remember correctly.
Scott
Bob
05-01-2008 16:34:44
WELL, if you REALLY have tried both ground polarities, so much for the electronic ignition module!
That (and the alternator, if used) are the tow determining factors as to what the ground polarity needs to be.
