70 Gas Spark Plugs
James Howell
05-01-2008 11:38:56
What Autolite spark plug would you recommend for a Model 70 Gas tractor?
Nancy and I are going to inspect a couple of Model 70's this Saturday.
Would like to help them along with new plugs.
Thanks in advance for all your help.
Andy Motteberg
05-01-2008 13:04:46
 Re: 70 Gas Spark Plugs in reply to James Howell, 05-01-2008 11:38:56
I'd use Autolite 3116, it is a non-resistor type spark plug and I use them in my tractors and they work great, also be sure to use copper core plug wires.
Andy.
James Howell
05-01-2008 14:39:57
 Re: 70 Gas Spark Plugs in reply to Andy Motteberg, 05-01-2008 13:04:46
I do use copper core plug wires on my tractors.
I buy the wire from one of the local NAPA stores.
One young salesman was surprised that I knew how to even make up a spark plug wire.
Thanks for the reminder.
John T
05-01-2008 12:36:53
Wow, lots of good plug questions lately. In the smaller plugs Id run the NON resistor Autolite 3116 which is in the heat range of the resistor 386 or hotter 388 buttttt ttttt its not a resistor plug. I dont believe in wasting potential spark energy in the form of heat losses in resistive plugs or wires as Id prefer to dissipate as much as possible across the spark plug gap. In the older 7/8 plugs I use 3077 as posted below.
John T
James Howell
05-01-2008 14:52:56
 Re: 70 Gas Spark Plugs in reply to John T, 05-01-2008 12:36:53
I read over several of the previous posts on spark plugs that I retrieved and saved from the archives, but found nothing regarding the Model 70.
I saw that you had recommended the same spark plug in a previous post earlier today.
Thanks for all your help that you provide to us on this forum.
I appreciate it very much.
