JD 202DE01_Trouble
Stanley5
05-01-2008 09:13:35
Trouble_ 202DE01_SN190671T diesel engine on 880 Windrower using coolant.
History_ The engine has never used coolant before and has never been overheated. We ran the engine with one bad injector for some time and considered that it may have caused an internal problem. We recently r&r four injectors and shortly after engine is consuming gallon(s)of radiator coolant every few hours. Upon pulling the head we found the head, gasket and liners appearing to be ok. With that being said, we believe the liner or liner seals are cracked and/or leaking. Has anyone experienced this problem before and what was the cause and recommended repair? Comments or suggestions are appreciated.
Roger in Iowa
05-01-2008 09:34:14
 Re: JD 202DE01_Trouble in reply to Stanley5, 05-01-2008 09:13:35
Where is the coolant going? Are you getting coolant in the oil? Oil turning milky? (liner seals at the bottom)
Is the exhaust showing white smoke? (head gasket or cracked head)
Are there bubbles in a FULL radiator?
That much coolant loss should be showing somewhere.
Roger in Iowa
Stanley5
05-01-2008 11:09:45
 Re: JD 202DE01_Trouble in reply to Roger in Iowa, 05-01-2008 09:34:14
Coolant is not leaking externally, no smoke that we could tell and no coolant initially mixing in oil or vice versa. It would take several hours (3-4) to use a gallon. Coolant must have been blowing out crank vent or exhaust in minute quantities. Coolant eventually made it to oil and that is why we pulled the head. Could not see bubbles in radiator coolant but noticed particles (carbon, oil, rust, perhaps?).
Roger in Iowa
05-01-2008 17:34:21
 Re: JD 202DE01_Trouble in reply to Stanley5, 05-01-2008 11:09:45
To see bubbles in the radiator, it has to be full clear up to the round hole below the cap. Absolutely full.
Since the coolant is eventually getting in the oil. Sounds like the packings at the bottom of the liners (sleeves) are going. That would be an overhaul job. Might leave the radiator cap loose to see if that helps. WAtch out for overheating.
Roger in Iowa
