7020 high / low shift
Ian T in AB
04-30-2008 19:41:06
I ended up with a 7020 4wd, the shifters in the dash gives it 8 speeds, the high low shifter on the far rh side of the cab make it 16 speeds, is the shifter on the rh side a power shift or are you suppost to use the clutch when shifting this one, if you go from low to high it grinds, when you go from high to low the tractor stops moving foward, step on the clutch, pull it back into high then it grinds but goes back into gear, all other gears work fine,or do I have a problem with the transmition or am I not shifting it properly, I havn't hooked up the cultervator yet, this is trying it out in the yard at 1200rpm, any info much apreciated
Ian T in AB
05-02-2008 21:49:33
 Re: 7020 high / low shift in reply to Ian T in AB, 04-30-2008 19:41:06
Thank you for info, no one around here has one, I'll giver a try next week, hopefully get it home soon
df
05-01-2008 17:08:47
I have one. You have to clutch when shifting. It has a splitter box for the hi/lo. If it is grinding there is and adjustment on the cable linkage.
Bud Sather in MT
04-30-2008 20:20:07
the high low gear shift is just like any other gear shift. Stop the tractor shift the gear and then start moving again. Using the clutch is a must.
Bud
RobMD
04-30-2008 20:03:05
I believe high low is a two speed rear end. You shift when stopped and with the clutch, then go. Going by memory here
francis
06-12-2008 18:36:42
 Re: 7020 high / low shift in reply to RobMD, 04-30-2008 20:03:05
better use that clutch,i just got my rear end back together,shift gently also,some reason of another my shift fork came loose or unriveted and dropped between gears i had to replace the top shaft after all this mess,,,the hi/lo is like another set of gears though,now mine has to be left in both neutrals at 1 time cause if left in N alone,and in a gear,,,it hops into gear and drives off a loittle ways then hops back out theres nothing out of adjustment either,,just be extra careful,,
