John Deere 40 with Bent Push Rod
Josh Satterfiel
04-30-2008 18:04:48
Hey, I have an old John Deere 40 with a bent push rod and was wondering if anyone knew where I could get one besides the John Deere dealer, because they are $53 a piece from there, or is that a good price for a push rod? Does the push rod just slide through the head and rest in the cam follower? is there a push rod guide or something else that needs to be replaced when replacing the push rod?
alabamafrog
05-03-2008 09:31:43
 Re: John Deere 40 with Bent Push Rod in reply to Josh Satterfield, 04-30-2008 18:04:48
I know it�s not the proper thing to do but it worked. A few weeks ago when I got our old MT out of the back of an old barn where it had been for 15 years I tried to pull it off with a truck. Long story short, the intake valve was stuck and I bent the push rod into an S. After freeing up the intake valve with a hammer and pry bar I beat the push rod back straight with a hammer on the vise and put her all back together. She fired up and ran good, a little tappet adjustment to all 4 valves and now she runs great. My John Deere dealer spent two days looking for the rod before telling me they were $58 each.
Lanse
05-01-2008 13:10:45
Thats not a good price at all. Vintagetractors has them for $10 each. I would look into what caused it to bent. My AC B had one bent but the engine was stuck
buickanddeere
05-01-2008 05:44:39
If a pushrod is bent. It's time to find out what else is broken and why. You are looking at a symptom, not the problem.
Josh Satterfield
05-01-2008 07:44:30
 Re: John Deere 40 with Bent Push Rod in reply to buickanddeere, 05-01-2008 05:44:39
the whole motor was froze from setting outside for a couple of years with water in the bock, I wouldn't think that the exhaust valve would be stuck, but it was, but I've already have everything else loose and going good, I just need to fix the push rod, because I don't want to run it with it bent.
teddy52food
04-30-2008 18:46:00
Make sure the valve is free so you don't bend another one.
RobMD
04-30-2008 18:12:55
Push rod sets in there by itself.
Contact one of the many salvage yards in green magazine... they're a dime a dozen used. 2 cyl plus tractor salvage 417 589 3337
