'36 B Oil components questions
Kris A NC
04-30-2008 15:42:37
First of all I have heard people talk about rebuilding oil pumps. What is all involved in this? When I had mine apart I didn't see much to rebuild. What am I missing?
Second, When I was running my '36 for the first time this past weekend I had low oil pressure. I turned the screw clock wise and got it just below medium with it screwed in flush with the lock nut. What am I missing? Is that all the higher it will go? I am using non-detergent 30w oil. Also, when I took the valve cover off to inspect the tappets and to adjust only #1 exhaust was getting oil. Before I put the valve cover on to run it I made sure I blew the passage out and ran a pick in the holes. It appeared the oil was entering the valve cover and running down the side and out the first hole. Now the tractor was sitting on a slope to that side a tad, but I wouldn't think it would affect it this much. Anything I can look for here? Thanks in advance
Kris A NC
d. coleman
05-03-2008 20:49:04
 Re: '36 B Oil components questions in reply to Kris A NC, 04-30-2008 15:42:37
very carfully disamble,noting location of every part. clean, clean, clean, with soft brush and solvent (NOT GASOLINE) ANY SPECK OF DIRT, GRIT, OR CRUSTED OLD OIL WILL BE THE FIRST THING THE MAIN BEARINGS SEE THEN ITS ON TO THE ROD BEARINGS AND CAM BEARINGS, SPRAYED ON CYLINDERS. reassemble with new lock washers. be sure the pick up screen is installed in proper location. did i mention to clean, clean, clean!!!? good luck, d. coleman
Duane Larson
04-30-2008 15:59:12
Kris,
Did you replace the oil pressure gauge? If so, there is a big difference in them - some are 50 psi full scale. Try to locate a gauge calibrated in psi and see what you get - it should be between 10-15 psi.
