24 Volt System Ideas, 730 D
Todd in TN
04-30-2008 04:04:24
Has anyone here ever simplified the 730 D 24/12 volt split system into a straight 24 volt system?
I know you can now get 24v light bulbs that probably weren"t available in 1958(I"ve already searched them online).
It could only make a more simple system with less wires and more equal battery drain. The only other thing to figure out would be the fuel gauge which should be easy for some of these electrical engineers on here :) I"m not worried about the implement socket on the batt box, I"ve never used it.
I"m getting ready to wire mine up with all new wiring/cables/batts/etc... I understand the split system very well, I"m just sittin" and thinkin"
Also, I"d like to know what batteries you guys have had the best luck with. I"ve heard that "Optima" work good in these tractors. There will be no compromises in this electrical system.
Todd
buickanddeere
04-30-2008 05:48:13
 Re: 24 Volt System Ideas, 730 D in reply to Todd in TN, 04-30-2008 04:04:24
It's still possible to get a short through chassis. All the 12/24V system needs is an extra solenoid at the starter and a relay at the generator.To isolate those two trouble spots.
Todd in TN
04-30-2008 06:52:34
 Re: 24 Volt System Ideas, 730 D in reply to buickanddeere, 04-30-2008 05:48:13
Yeah, I thought of hiding a ford type solenoid under the hood. Where do you hide your relay? Got a wiring diagram? My other option is to put a switch on the jumper between batts that will kill 24v and also switch off the 12v ground wire between batts, be nice if I could conjure up a switch that would isolate all three cables/wire.
Thanks!
Todd
buickanddeere
05-01-2008 05:47:24
 Re: 24 Volt System Ideas, 730 D in reply to Todd in TN, 04-30-2008 06:52:34
Just put a relay in the "always live" lead to the generator. Have the relay close with an oil pressure switch for simplicity.
kendak
04-30-2008 10:27:57
changed mine over to - ground ...put a 24v IG alt.on it ...B+ runs to starter ...B- runs to starter ground ...resister under dash drops 24 down to 12 for switch & start button...volt meter on dash going to any hot point...[2] group 27 [750amps each]wal-mart batterys will start it without decom....Kent
