2040 two stage clutch adjustment
Guncase
04-29-2008 17:44:30
How do I adjust the two stage clutch? This tractor has a loader, and when disengaging the clutch, I lose hydraulics because both stages are disengaging and the transfer pump in the case stops supplying oil to the high pressure pump in the front of the tractor.
Tx Jim
05-02-2008 14:01:44
 Re: 2040 two stage clutch adjustment in reply to Rich Duane, 04-29-2008 17:44:30
buickanddeere
Thanks for posting all those part numbers. It made me feel younger as to back to my youth when I stood behind a JD dealers parts counter and in the service area! Maybe oldtimers hasn't totally set upon me.Thanks again,Jim
buickanddeere
05-02-2008 07:20:56
 Re: 2040 two stage clutch adjustment in reply to Guncase, 04-29-2008 17:44:30
That's pretty amazing, I stand corrected. Looks like there was an odd early Dubuque built version of th 2040 with open center hydraulics for the US market ???
A serial number and some info from the guy with the questions would have helped.
Close, it was a 2nd oil cooler, not a 2nd oil tank for those 1640/1840/2040 models. I am certain somewhere there is a 2nd tank used on some models.
Any later Dubuque built 2040's and all Mannheim built of the 1640/1840/2040 were all closed center.
Any 1640/1840 which is a 2040. Were all and always closed center hydraulics shipped here. There was even a choice of three different displacement closed center pumps. 0.7cu", 1.4cu" and the 2.4 cu".
Open
11CM3 (0.67 IN.3))
(TRACTOR SERIAL NO. -266749)
Cart KEY PART NO. PART NAME QTY TRACTOR SERIAL NO. REMARKS
1 AT28460 HYDRAULIC PUMP 1
(SUB AL37751, AL36652, AL36654, (2) 12H293 AND (2) 19H1828)
Closed
23 CM3 (1.38 IN.3))
(TRACTOR SERIAL NO. 266750- )
1 AR103033 HYDRAULIC PUMP 1
23 CM3 (1.38 IN.3) (SUB FOR AR39168 OR AR89064)
Open
(POWER STEERING PUMP)
(11CM3 (0.67 IN.3))
HYDRAULIC PUMP (OPEN CENTER) - CONTINUED
(11 CM3 (0.67 IN.3))
Closed
Cart KEY PART NO. PART NAME QTY MODEL NO. REMARKS
.. AR103033 HYDRAULIC PUMP 1
(A) (SUB FOR AR39168 OR AR89064)
AL31897 HYDRAULIC RESERVOIR 1
(SUB AL40831 AND AL40832)
1 AR62440 RESERVOIR 1
2 T22970 PLUG 1
3 U11343 O-RING 2
4 AT20983 FITTING 1
5 D2361R BALL 1
13MM (1/2") CHECK VALVE
6 R39078 SPRING 1
7 R39076 GUIDE 1
8 AT20960 OIL LINE 1
(OIL PUMP DRAIN)
9 19H1936 CAP SCREW 2
3/8" X 3/4"
10 12H304 LOCK WASHER 2
3/8"
11 AT20961 OIL LINE 1
(TO PUMP)
12
HOSE 1
19 X 64MM (3/4" X 2-1/2") (MAKE FROM TY22563) (SUB FOR TY22329)
13 T23104 OIL LINE 1 -279042 (TO CLUTCH OIL HOUSING OIL LINE)
L33840 OIL LINE 1 279043- (TO CLUTCH OIL HOUSING OIL LINE)
14
HOSE 1
19 X 129MM (3/4" X 5-3/32") (MAKE FROM TY22329) (SUB FOR R32087)
15 AR21839 CLAMP 6
(SUB TY22467)
16 R27531 CLAMP 2
17 37H84 SCREW 2
1/4" X 3/4"
18 24H1289 WASHER 2
21/64" X 5/8" X 0.049"
19 L35844 HOSE 1
(SUB L35843) (HI-LO SHIFT)
20
HOSE 1
19 X 86MM (3/4" X 3-11/32") (MAKE FROM TY22563) (SUB FOR R34147 OR TY22329)
21 T23073 TUBE 1
BLEED (TO CLUTCH HOUSING)
22 T19324 CLAMP 2
23 R44302 TIE BAND 1
1640, 1840, 2040 Tractors ( -429999) European Edition
Page Name: SECOND OIL COOLER
AL35629 KIT
Tx Jim
05-02-2008 04:50:13
 Re: 2040 two stage clutch adjustment in reply to Mr pete, 04-29-2008 17:44:30
Buickanddeere
You are incorrect in stating that all 2040's are closed-center hyd's. The first ones were open-center similiar to the 3cyl. 830's. Also would you please explain which models 2 hyd storage tanks were optional on if you aren't refering to the transmission as one of them?
Tx Jim
Edpap
04-30-2008 18:22:30
Hello Guncase,
there is a good layout on how to adjust the release levers in IT manual JD202 paragraph 110. I wish I could send it to you. They say it much better then I can.but you unhook the clutch pedal, go inside the bell housing from the side turn out the clutch operating bolts until the lever hits the throw out bearing then turn them back in 2 1/2 turns and lock the nut. I can't say this will solve your problem. I had 4020 that the hyds would kick out when you sat with clutch down I always though it was a internal leak inside. and it had no tank on top of the pump. I see you tractor has a large hyd tank above the pump. it might be that tank is not getting filled with oil. but I have never seen a 2040 before. Good Luck Ed
Guncase
04-30-2008 20:42:58
 Re: 2040 two stage clutch adjustment in reply to Edpap, 04-30-2008 18:22:30
Thanks for the info. I have seen other tractors with the tank above the pump, but mine doesn't have it. I was told that the tractors with the piston pump have a reservoir, and tractors with gear pump do not.
Edpap
05-01-2008 05:38:53
 Re: 2040 two stage clutch adjustment in reply to Guncase, 04-30-2008 20:42:58
Ok so that means you have an open center hyd system. so there should be a supply by-pass valve that opens when there is a negative pressure in the supply curcit. the problem is I can't seem to find it in the manual. but i would say the first thing I would do is clean the suction screen and change the filter and look for air leaks in the suction hose. if that dosent solve it then I would try and find that valve. the tractor hyd should work when the clutch is in or out with a gear pump.
Good Luck Ed
buickanddeere
05-01-2008 05:50:49
 Re: 2040 two stage clutch adjustment in reply to Edpap, 05-01-2008 05:38:53
A 2040 is closed center. Still haven't heard how the loader is plumbed to the tractor. That is important. Is it connected to the rear hydraulic remotes? Every tractor had one hydraulic storage tank, a 2nd was optional. I can't even guess why you are tinkering with the clutch and be thinking hydraulics. Have you read the operator's and service manuals?
buickanddeere
04-29-2008 18:50:14
You should not be loosing hydraulics.How are the loader hydraulic tied to the tractor hydraulics?
Guncase
04-29-2008 18:15:56
They came both ways according to the operators manual. Mine has the continuous running pto and two stage clutch
RobMD
04-29-2008 17:46:29
I was unaware that a 2040 had a two stage clutch... thought they were all Independent PTO
