Can the PTO be in reverse direction 850
Fast850
04-29-2008 17:11:08
I have a augar bit stuck in the ground. I need to reverse the PTO on my Deere 850.. can this be done?
RobMD
04-29-2008 17:37:56
 Re: Can the PTO be in reverse direction 850 in reply to Fast850, 04-29-2008 17:11:08
No.
Put a pipe wrench on the driveshaft with the engine off and reverse it manually. It will come out enough so you can lift it out.
Fast850
04-29-2008 22:35:12
 Re: Can the PTO be in reverse direction 850 in reply to RobMD, 04-29-2008 17:37:56
Yes, thank you for the answer to try... well, I got it out after about 2 hours of digging. The bit was sunk in at all the way to the gear drive. that was about 4 feet. Black Clay wet dirt. I dug to the top of the first spiril on the bit, and then wide open throttle, and dump the PTO... Oh, I had to most important put jacks under the lift arms so the front end did not come off the ground and sink the bit again.
ebbsspeed
04-30-2008 07:04:18
 Re: Can the PTO be in reverse direction 850 in reply to Fast850, 04-29-2008 22:35:12
Sounds like your method is a good way to break something. WOT and dumping the PTO clutch is a bad combination.....
