My 4020 ran that way when I got it. It runs much better now. First thing is to replace the float needle and seat. Its worn and leaking keeping the gas level too high in the float bowl. I asked a similar question of the gas engine guru at a local JD dealer's shop and he said he had methods of helping but if I hadn't replace float needle and seat he wouldn't talk to me. At the time I had the new float needle and seat in a sack in my hand. I've not been back to see him. I also found the choke wasn't opening all the way. The choke cable sheath wasn't anchored near the carburetor. I found the top of the Donaldson precleaner was pulled down reestricting the air intake. I was able to reshape it domed up. A dirty air cleaner (4010 was oil bath) can restrict intake air and make the engine run rich. There was loose junk in my intake manifold above the carburetor, removing that helped. Its easy for mud daubers to build in the intake pipes, they restrict air flow. I went to AC plugs and new copper wires, the carbon wires were breaking and making the tractor run rough. Before I did these things my 4020 smoked (black) like an IH diesel with a black cloud above it at idle that mushroomed when I opened the throttle. With these fixes, I cut fuel consumption (doing the same work) from 400 to 250 gallons a year. I have to choke it for all starts, warm or cold. The exhaust is clean. I think I have it lean enough. I did not adjust the mixture screws on my Zenith carburetor. Adjusting the M-S diecast aluminum monstrosity is much more difficult and even in about 1970 there was a JD Service Bulletin suggesting replacing the M-S with a Zenith so it can be adjusted properly. Gerald J.
