JD 1010 rear wheel
jwhart
04-29-2008 11:11:43
Im still trying to remove rear wheel from 1010. Tried Heavy duty puller and oxy/acet torch with still no luck. Anybody have any more ideas? Someone suggested removing the final drive like newer machines. What would be the best way to go about this?
Loren NC
04-29-2008 16:12:54
 Re: JD 1010 rear wheel in reply to jwhart, 04-29-2008 11:11:43
Are you trying to take the wheel off the hub or the hub off the axle? I have gotten both my wheels off the hubs but can't budge the hub on the axle.
One suggestion I have heard is to loosen the lugs only slightly, enough so the shoulders are not touching the holes, then drive the tractor. Might work but thankfully I didn't have to do it.
jwhart
04-30-2008 05:15:15
 Re: JD 1010 rear wheel in reply to Loren NC, 04-29-2008 16:12:54
Yeah I'm trying to get the hub off the axle. Ive heard that suggestion too, about driving it,but i've got the whole tractor broke down so thats not really an option right now. I've got a neighbor who has a port a power. Going to try that tonight, maybe I'll have some luck. I new how easy the other side was, it was too good to be true. Thanks for your help jw
