3020 Fuel Gauge Problem
glsinNY
04-29-2008 05:51:06
I just installed a new fuel guage. When the switch is in the "on" position it does not work, when the tractor is running it is pegged on "F". There is less than a quarter in the tank. The old one did not work at all. Could it be the sending unit?
Bob Bancroft
04-29-2008 14:22:07
 Re: 3020 Fuel Gauge Problem in reply to glsinNY, 04-29-2008 05:51:06
I believe your new guage has both positive and negative terminals on the back so it can be hooked up correctly whatever your polarity. In any of these systems the sending unit is usually the part that gives out most often.
Bob
04-29-2008 06:54:39
Is this a 24-Volt system?
IF SO, ar you missing the centerpoint-of-the-batteries ground wire/fuse/fusible link that connects to chassis groud?
glsinNY
04-29-2008 08:04:00
 Re: 3020 Fuel Gauge Problem in reply to Bob, 04-29-2008 06:54:39
Bob, It's a 12 volt system. The generator was replaced with an alternator by previous owners. It does have a fusable link to the coil that looks to be added as it is a blade type fuse. It's and early 3020, #62775 made in '64. It only has one battery box, so I do not think it was converted from a 24 volt system
jturbo10
04-29-2008 13:05:13
 Re: 3020 Fuel Gauge Problem in reply to glsinNY, 04-29-2008 08:04:00
Is your tractor negative or positive ground. I believe alternator conversions required negative ground systems but I believe the fuel sensing system is setup for positive ground on the early 3020s.
