Drive pin for spacer on flywheel
Bob with a 37 A
04-28-2008 15:59:00
I took off my flywheel and the drive pin that drives the spacer (oil slinger I think is what some call it)is just not there part #D2009R. It is available but I can't see how it attaches to the flywheel. Does it go in the deep groove where the set screw goes to time the flywheel? Or is there another place I just cant see? just not sure how it is supposed to be because its not there now. I have a parts manual but the old manuals don't show the pictures in a schematic like the newer A does. And there is no shop manual for the old gals.
Lee B
04-29-2008 23:55:02
 Re: Drive pin for spacer on flywheel in reply to Bob with a 37 A, 04-28-2008 15:59:00
I&T manual:
When reinstalling flywheel make certain that pin in flywheel aligns with notch in spacer and flywheel is installed in correct postion on shaft and securely tightened. Deep keyway of flywheel should be placed over locating screw on shaft; or if wheel hub carries a rivet, the rivet should be engaged with cutaway spline of shaft.
But no picture...
sgt bull
04-29-2008 12:32:55
I may be mistaken, but on the unstyled stuff, the driving pin was a cast nib in the flywheel... it may be broken off. Simply drill a new hole and tap it for the driving screw used on later tractors.
Maark
04-28-2008 16:54:06
The pin lines up with the square notch in the flywheel spacer that contains the cork seal.
kendak
04-28-2008 16:49:47
there's a hole drilled in flywheel inner surface that the pin fits in...a lot of them break out & wallow the hole out...just drill a new one it doesn't time to anything...Kent
