1020 starved for gas
Handsome Jim
04-28-2008 15:50:35
I've been having this problem with a 1020 for awhile now and have been trying this and that to remedy the situation. I'm pretty sure it's a fuel problem so the other day, I took the gas line off at the fuel pump and hardly any gas came out at all. I took an air hose and blew through the line back to the tank and gas started to run out steadily but not full. I reconnected the line to the fuel pump and ran the tractor for awhile and it ran OK for about an hour when it started to spit and sputter again. Question, since there is no inline or any other type of fuel filters on a 1020 gas, is there a screen in the tank? If there is, how do you go about cleaning it? Thanks, HJ.
Handsome Jim
04-30-2008 16:11:47
 Re: 1020 starved for gas in reply to Handsome Jim, 04-28-2008 15:50:35
Thanks for the help every body, you gave me some good things to check on. I didn't know that there was a screen in the line going to the carb. I did take the line off at the fuel pump on the tank side. Many thanks.
Mike M
04-29-2008 07:12:00
Did you unhook it before the fuel pump or after it ? There is also check valves built into the transfer pump that may be messing up. Might be a good idea to drain the tank and remove the shutoff valve and then flush the tank out and look into it with a flashlight and make sure it is clean.
lekander1020
04-28-2008 19:58:55
I found a screen in the elbow leading into the carb. If you unscrew the elbow there should be a cylinder style filter where the fuel line enters. But my problem wasn't there. I had to adjust the load jet just below the carburator to get mine to run right. Hope this helps.
Ten-Twenty
04-28-2008 17:12:33
HJ,
On page 25-1 of the 1020 parts catalog (Key #17) there appears to be an upright screen on the fuel shut off valve that is threaded into the bottom of the fuel tank.
Sam from WA
04-28-2008 16:39:47
Sounds like you might have some rust or other junk in the fuel tank. Try cleaning out the fuel tank.
