2840 - remote control valve rebuild?
tomtractor61
04-28-2008 15:39:48
When I run a remote cylinder on my 2840 it constantly creeps. It is slow but it creeps. I got a rebuild kit for the valve and then found out that the IT manual says I need a set up plate to adjust the valve after rebuilding it. Do I need the set up plate or can I get the valve rebuilt without it?
rexhellwig
04-28-2008 16:44:09
 Re: 2840 - remote control valve rebuild? in reply to tomtractor61, 04-28-2008 15:39:48
Bad news.
Your "rebuild kit" isn't really a rebuild kit. Think of it as more of a "gasket set". If a cylinder is creeping upward and the valve was correctly adjusted, it means the pressure poppet is leaking and also needs replaced.
If the seats in the housing are not perfect, they will need to be re-ground with a special tool. This is a job for a skilled Deere guy.
