Flat Spoke Wheels
gtop
04-28-2008 14:47:48
I have B model with flat spoke wheels. My question is did John Deere make flat spoke wheels for use with rubber tires. The reason i;m asking is because someone told me my wheels are rare and valuable. Thanks
Duane Larson
04-28-2008 20:51:24
 Re: Flat Spoke Wheels in reply to gtop, 04-28-2008 14:47:48
gtop,
Your unstyled B should have 10-spline axles, and the only flat spoke wheels available for them would be the late replacement wheels with a bolt-in hub. The hub casting number would be B2187R, with a B2189R clamp, and the wheel would be JD1270R (with a 6.00S-36 conventional rim) or JD1271R (with a 8.00T-36 conventional rim - a bit wide for a B). The JD1270,71R wheels were used on both A's and B's, and came along in the mid 1940's as a general replacement unit for the one-piece wheels with cast-in hubs (which had a habit of breaking).
Yes, the hub is fairly rare for the unstyled B, as it was a replacement wheel. The wheels are easier to find. Unstyled B's never came with flat spoke wheels for rubber.
Deere Breath
04-28-2008 19:59:50
I had 2 '39 B tractors with factory flat 12 spoke wheels with rubber tires. Yes the wheels are rare and valuable if the hub area is not broken (common problem) I took one pair to Waukee Ia swap meet about ten years ago and a man from texas was delighted to find them and took them home. John Deere made replacement wheels for these that had 14 spokes and a bolt in hub.
James Howell
04-28-2008 17:54:05
I have seen original factory flat spokes on a 36B and on a 39A.
Original factory spoked wheels, flat or round, are valuable.
This is a good question to ask Duane Larson. He is the "expert" on JD wheels.
gtop
04-28-2008 16:48:43
Thanks for the reply.Its an unstyled B. No serial tag so I dont know the year. Are these wheels hard to find and worth much?
Jim Broughton
04-28-2008 15:46:41
You didn't say if your "A" is styled or unstyled
anyway, the flat spoke rear wheels came out on the early,unstyled JDs, and yes, they were made for rubber tires....if memory serves me, the last year for the flat "slat" rear wheels was about 1938, though some early 39 "styled JDs were delivered with those wheels on them. Hope this helps some. Jim
