7520 AC Condenser
Greasey Hand
04-28-2008 13:16:51
Has any one ever put a AC condensor in front of the radeator insted of in the cab roof?
Will it be to much dust & dirt for it there?
It should cool better there shouldn't it?
Lee B
04-30-2008 00:22:17
 Re: 7520 AC Condenser in reply to Greasey Hand, 04-28-2008 13:16:51
1) 4630 has it that way from the factory as do most other tractor offerings with factory air. Putting it ON top of the cab roof would require an electric fan to cool it with, but then it's not blocking air flow to the engine and possibly is in a cooler place so as to work better.
2) Nope.
3) Maybe, but as rexhellwig hints at, the main limitation on using our raw Horse Power is heat expulsion and we are all behind the 8-ball because the manufacturer will never really adequately size the radiator for "extra" loads when it's in his favor all along to undersize that component to save big $$$ and help to insure that his engine is not critically overtaxed before the warrantee runs out. Adding an extra heat load to an already overloaded system will lead to overheating - if you can live with it, go ahead. If you don't work yours to such extremes then lucky you, it should work fine there.
aftermarket parts
04-28-2008 22:31:17
Some have done it that way when putting a sound gard cab on them but like said might overheat and need more cooling.
robertq
04-28-2008 19:30:14
it will work,I have seen it done,whats wrong with your roof top components?
Greasey Hand
04-30-2008 05:17:00
 Re: 7520 AC Condenser in reply to robertq, 04-28-2008 19:30:14
On the 7520 The compressor is no good, Locked up.
All the rest of the components are in the cab roof, Heater,condenser,dryer,evaporator, Its all in there, All factory.
I just thought that being other tractors, cars etc. Have the evaporator in front of the radiator
that it should cool better.
But there could be a cooling problem with the motor.
Thats why I asked if any one had done this & were there any problems.
rexhellwig
04-28-2008 16:18:38
I'll bet it could be done. It would be nice if you had your own salvage yard to see what would fit best. Take a look at an 8430 or 8440 and see if you can make the mounting like this. If the radiator has been staying clean, adding a condenser in front of it shouldn't make any difference as long as the side screens still fit OK.
I don't know where you live, but around here when it gets to 100 degrees, it is hard to keep a full power 7520 engine cool. If yours tends to run warm on a hot day, the extra heat and air restriction just might make it overheat.
I have a hunch why you might be trying to do this. Is that old condenser unavailable or $$$ ? If it is a "ribbon" type condenser, they are pretty hard to flush internally.
Some of those electric condenser fans are pricey, too.
thurlow
04-28-2008 15:11:25
Are you sure you understand about evaporators and condensors? Maybe do a search about the way (tractor) ACs work?
Greasey Hand
04-30-2008 05:30:22
 Re: 7520 AC Condenser in reply to thurlow, 04-28-2008 15:11:25
thurlow: Im cert on AC, My son is still doing his best.
So dont ditch about what its called every one here knows what were talking about.
