70 D clutch repair
Dan in Ohio
04-27-2008 15:23:26
In the process of over hauling the clutch as the pulley is slow to stop spinning after it is disengaged. Have noticed the pulley brake set screw is turned in all the way. Have the linings out and ready to take the pulley off thinking I should replace the pulley brake operating pin. Should I replace that operating pin or leave it alone. Otherwise the clutch operates fine and I will replace all the discs with a kit from WTR parts.
Rich Duane
04-27-2008 18:13:57
 Re: 70 D clutch repair in reply to Dan in Ohio, 04-27-2008 15:23:26
It will not be a waste of time taking the pulley off. It probably hasn't been off in years and is in need of having the carrier bearing repacked. When retightening the drive disc JD recomends 195# torque, If not tightened properly it leads to destroying the tapered splines on the crankshaft and the clutch drive disc.
Rich Duane
Dan in Ohio
04-27-2008 16:42:06
Mike, It looks like the previous owner tried that as well as replacing the two floating discs (the cheap ones). I think I will get and install the kit and see how it works. I do not want to remove the pulley from the tractor unnecessarily.
Mike M
04-27-2008 16:29:28
Sounds like a new pulley brake lining would of taken care of it ???
Some of those diesels require some special attention to adjust the pulley and brake assy. Not sure which ones require what without looking in the book as they changed design a few times from the 70 to the 720 to the 730.
